Latest post 01-31-2012 11:44 AM by vivvers48. 5 replies.
Page 1 of 1 (6 items)
  • 06-02-2011 9:27 PM
    <help!> about beocom 6000 MKI pin code
    my friend send a beocom 6000 MKI set to me but he forget the pin code for registering the handset to the pyramid base. Anyone can help reset it ?
  • 06-03-2011 10:09 PM In reply to
    Re: <help!> about beocom 6000 MKI pin code
    If your friend changed the code, B&O will have to change a chip or something like that, but if he did not change it it should be 0000.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 06-04-2011 12:10 AM In reply to
    B&O refuse to help cuz i am in China now. Local dealer said they won't even check the problem cuz it is US version.
  • 06-16-2011 2:32 PM In reply to
    If you'd like, PM me the serial of the phone and I'll check for the pin code on B&O's ROS system.
    It blows my mind how some dealers can be soooo unhelpfull. You come down to our store in Calgary and you'll get a cup of NESPRESSO to help you ease the "wait time" as I fill out the service claim forms and send the item out for repair. That's the level of service and customer appreciation that we have here for our clients.
    ... then again... some care and some don't.
  • 06-16-2011 3:11 PM In reply to
    The pin code is not on ROS, but is is a PIN that can be set to make sure that someone else does not register a handset to your base. Like that is ever going to happen! So in my opinion the PIN in BeoCom 6000 causes more problems than it is useful.
    Anyhow, the Pin code can only be reset by Bang & Olufsen at a Service Center as far as I know, even a dealer cannot reset it. So maybe you can contact the B&O office in China?
  • 01-31-2012 11:44 AM In reply to
    Message to Oakley,
    Hi Oakley,
    I have the same problem that Volcanor had last year, I’ve been given a Beocom 6000 setup but two of the hands are locked and I wasn’t told the pin code.
    I’m in the UK, my local dealer closed down a coupe of years ago, and Calgary’s a touch too far to visit, but I wonder whether you would be so kind as to check B&O’s ROS system and identify the pin code/s for me?
    One is serial number : 106154688180217
    One is serial number : 106144888179949
    I very much hope you can help me.
    Best wishes, Viv
