Latest post 05-30-2011 2:44 AM by tournedos. 5 replies.
Page 1 of 1 (6 items)
  • 05-29-2011 3:51 PM
    Master control panel 5000 witrh beosystem 3300?
    anyone that knows anything about this? doesent seem to work =/
    there must be something i can do
  • 05-29-2011 4:27 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Master control panel 5000 witrh beosystem 3300?
    No - the MCP5000 will NOT work with the Beomaster 3300 as they use different IR codes.
    What can you do? Get a beolink 1000 & now is definately the time to buy one. Recent ebay prices seem to suggest you can pick one up for around £20 at the moment.
    Chris.
  • 05-29-2011 4:33 PM In reply to
    awwhh, well thats sad =/ so none of the MCP's will work with my 3300 system? =/
    isnt there any part i can change or W/E?
    will the beolink 1000 work tho?
    thnx for ur time!  :)
  • 05-29-2011 5:16 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    None of the Master Control Panels will work with a Beomaster 3300.
    It would take a huge reprogramming (rebuild!) to make it work.
    The Master Control Panel relies on the Beomaster to answer back, which a Beomaster 3300 cannot do.
    As Chris suggests, get a Beolink 1000. It will work and prices are low right now.
    Alternatively a Terminal 3300 but that may be more expensive, harder to find and the
    general opinion seems to be that it is not as stylish a remote as the Beolink 1000.
  • 05-30-2011 2:21 AM In reply to
    An MCP5500 will work - but only one way. You will be able to control the system but you won't get feedback.
  • 05-30-2011 2:44 AM In reply to
    Peter :
    ...and it will be extremely annoying, as I recall the MCP won't allow another keypress until the previous one has timed out with "no contact"! Volume control especially will have you throwing the MCP out of the window in no time...
    -mika
