Latest post 06-09-2011 6:38 AM by Peter. 6 replies.
Page 1 of 1 (7 items)
  • 05-29-2011 9:47 AM
    • Peter
    • Top 500 Contributor
    • Joined on 12-28-2009
    • Sweden
    • Posts 134
    BV 4-42 and BV 4-50 and motorized stand..
    Hi all!
    I am looking into buying a used BV 4-42 or BV 4-50 but I am not planing to put it on the wall.
    Does those two TVs has the built in feature to control a motorized stand?
    /Peter
  • 06-07-2011 6:01 AM In reply to
    • Peter
    • Sweden
    • Posts 134
    Re: BV 4-42 and BV 4-50 and motorized stand..
    Anyone? :-)
  • 06-07-2011 9:09 AM In reply to
    • frog
    • Joined on 04-19-2007
    • Posts 191
    Beovision 4 is a plasma panel - not a TV, so doesn't have the features you would have on a Beovision TV (like stand adjustment).
    You basically nail the screen to the wall (or use a panasonic table stand) and it is static unless you get some kind of third-party mounting bracket that is motorised. I don't know of one that can be controlled directly by the Beo4 remote
  • 06-07-2011 10:15 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Willich, NRW, Germany
    • Posts 1,077
    One of the site's sponsors has some kind of motorized wall mount...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 06-08-2011 5:43 PM In reply to
    • brulz
    • Not Ranked
    • Joined on 04-29-2008
    • Posts 6
    http://www.stbbrackets.co.uk/?page=prodlist&catID=1
  • 06-08-2011 11:24 PM In reply to
    • akoro
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    Why not a BeoVision 9? It has super center speaker, BeoSystem 3 and a motorstand.
  • 06-09-2011 6:38 AM In reply to
    • Peter
    • Sweden
    • Posts 134
    Thanks for the answers!
    I was suspecting there were no connection for motorsized stand on BV4-42, Thanks for clearifying that.  Ive seen some table stands, but I guess they are motorized then.
    @akoro: Yeah that would be a dream! :-) I am looking into buying a used BV4-42 or BV here, since a second hand BV4-42 can be found at a price around 1000 euros over here, BV 5 is about twice the price...a second hand BV9 is about 8-10 times as much. So unfortunatly that is way out of my reach ...but yes, its a wonderful set that has it all..
     /Peter
