Latest post 05-31-2011 4:03 AM by Step1. 8 replies.
Page 1 of 1 (9 items)
  • 05-28-2011 4:03 AM
    • JSB
    • Not Ranked
    • Joined on 06-01-2007
    • Posts 7
    LC2 Light Controller, circuit diagramm or service manual
    Hello BeoWorld members,
    One of my LC2 Light Controller is broken-down.
    Does anybody has a circuit diagramm or service manual?
    Thank you for your feedback.
    Klaus
  • 05-28-2011 5:43 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: LC2 Light Controller, circuit diagramm or service manual
    I also need a diagram, but I suspect it is locked away within the B&O vaults somewhere, never to see the light of day again!
    Maybe a letter to B&O themselves but make sure it is sort of, 'authorative' in some way!
    These units are relatively simple though, and I am sure if you describe the symptoms there is a chance the fault could be located...
    Olly.
  • 05-28-2011 8:52 AM In reply to
    http://www.abo-center.dk/Abo_center_2/reptips/LCrep/Rep%20lc2.pdf
  • 05-28-2011 8:56 AM In reply to
    It is in Danish but you can use Google tanzlator :)
  • 05-28-2011 9:58 AM In reply to
    Google translation
    Forget the programmed number of blackout ( Hmm ):
    EEPROM IC3 defect
    No operation with touch, IR ok:
    Silver layer on top is bad. Repair it or replace IR cover
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 05-30-2011 2:58 AM In reply to
    Leslie:
    Google translation
    EEPROM IC3 defect
    Blackout is not really the correct translation. More correctly it should be Forget the programmed number when no power (or power off).
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 05-30-2011 4:00 AM In reply to
    JSB:
    Klaus
    Klause,
    The Service Manual is now available for download...
    Regards Keith....
  • 05-30-2011 4:45 PM In reply to
    • JSB
    • Not Ranked
    • Posts 7
    Hello Keith,
    Great!
    Thanks a lot
    Klaus
  • 05-31-2011 4:03 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Where did that come from?! Nice one!!
    Are there any more manuals waiting in the wings to surface Keith?
    Olly.
