Latest post 05-29-2011 3:24 PM by AT. 2 replies.
Page 1 of 1 (3 items)
  • 05-26-2011 4:06 PM
    • AT
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 187
    Serene ringtone question
    Hi All,
    I have a Serene, and a question.
    I want to use different sound patterns for different persons, but as far as I can see, it's not possible. Even there is a choice for grouping the persons, there is no choice for a special sound. Also, a name can be paired with a picture, but not with a sound.
    Did I missed something, or my wish is really not supported by Serene?
    Thanks in advance for any idea!
  • 05-27-2011 11:40 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Serene ringtone question
    I am not near my Serene right now, so I cannot confirm. Is the feature listed in the manual?
    ...if I had to guess, I would say no - the Serene won't...
    Evan
  • 05-29-2011 3:24 PM In reply to
    • AT
    • Posts 187
    First of all, thank You for the answer. I was not satisfied with Serene's manual, but if You also don't know about this feature, I will forget it. Anyway, sometimes I can't understand B&O's thinking: If there is a possibility to add a picture to any contact, why it's a big deal to add a ringtone? Anyway I wish to mute some calls, but I will manage it in a different way Smile
    Thanks again Smile
