Can anyone advise me on what I'm doing wrong with my TV and speaker setup please?
I have a BeoVision 5 TV with 4x speakers
2x 6000 speakers at the front (one either side of the TV). The left speaker is plugged into the front left port on the TV and the right speaker is plugged into the front right port of the TV. The TV and these 2 speakers work fine, it's the rear ones I have a problem with.
I also have a BeoSound Overture at the rear of the room with 2x Beolab 4000 wired up to it. The 2x speakers are linked together with one of the speaker cables going into the back of the BeoSound. The other speaker port on the back of the BeoSound runs a speaker cable to the BeoVision 5, plugging into the right, rear speaker port on the TV. There is also a masterlink cable running from the TV to the BeoSound.
When I go to the setup on the TV all four speakers come on once selected within the menu and the correct sound comes out of all 4 speakers as well as the TV. The minute I come out of the speaker setup menu the 2 rear speakers turn off.
Someone mentioned to me that the TV may be set up with only 2 speakers instead of all 4 from within the setup menu, but I can't seem to find anywhere where I can change this. Is this correct?
Can anyone help please?
