Latest post 05-26-2011 11:09 AM by Peter. 8 replies.
Page 1 of 1 (9 items)
  • 05-24-2011 11:36 PM
    Bang & Olufsen s82 vintage
    I have a set of two Bang & Olufsen s82 vintage I guess they are called, they are just the two speakers with the crossover circuit boards on the speaker housing. I am curious to know the value.
  • 05-25-2011 1:34 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Bang & Olufsen s82 vintage
    Welcome to Beoworld !
    S82 is not something, I've heard before.
    Are you sure they are not S22 or S80.2 ?
  • 05-25-2011 11:09 PM In reply to
    Well they are an older set I am not totally sure about the model but I am particularily sue that they are s82.
                                   please reply I enjoy feedback
  • 05-26-2011 2:04 AM In reply to
    Very difficult to feedback if we are not sure of the model. There should be a label on the back with a T number on - this will tell us the model. A picture would also help.
  • 05-26-2011 7:40 AM In reply to
    S80.2?
  • 05-26-2011 10:34 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, I already suggested that too.
    I don't know all of B&O's speakers but I do know a lot of them, also some of the more exotic ones
    and I've never heard of S82, nor does a search through all my collected documentation reveal any clues.
    (Except for the VHS82 but that's a video tape recorder).
    The fact that you have a pair suggests that we are somewhere in the
    stereo age, in the Beo world that means apprx. 1962 and up, but that's just a guess.
    It's certainly possible to have two older speakers.
    Can you provide us with a photo or somehow describe the speakers for us ?
  • 05-26-2011 10:59 AM In reply to
    If you are not able to post photos I suggest you go to the top of this page, choose "Main site", there choose "Products", there "Product Browse", in the 1st select box, "speakers", the 2nd "Beovox", the 3rd "all products", there you will find a list of nearly all Beovox speakers produced. Check one by one, and maybe you will find yours.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 05-26-2011 11:08 AM In reply to
    Searching the net I found a Acustic Design speaker named S82, big, ugly and black
  • 05-26-2011 11:09 AM In reply to
    If it is S80.2, the answer is slightly complicated!!
    The S80.2 is a good speaker - however the bass unit suffers from foam rot and almost always needs repairing. The capacitors in this model are also likely to be in need of repairing.  The pair pictured here were mine and required both new capacitors and new foam surrounds. They were actually given to me free by my old dealer a good number of years ago so I think I can say that the value of these is not high. A shame, as they really are rather good sounding. I suspect a pair will reach up to £75 on eBay.
