My Beolink IR eye "play" button is not responding, and thus my 9000 will not turn off! When I push the button manually, nothing happens. When I use the remote control, the red dot on the play button blinks but will not stay on (normally lit up means that the 9000 turns off). However, I can control the volume both manually and via the remote control. Similarly, the timer button works. Has anyone else experienced this problem? Thanks!
