Latest post 05-23-2011 6:49 AM by gilbert. 5 replies.
Page 1 of 1 (6 items)
  • 05-21-2011 1:52 PM
    Display Beolab 4500
    I have connected the BeoLab 4500 to the Beomaster 7000 with a new power link cable but do not appear information on the display of the beolab. When I plug the BeoLab 4500 to the electricity there is a red dot on the display. Is required Beomaster 4500 to see information on dysplay of beolab or is necessary an old power link cable?
    Filed under:
  • 05-21-2011 2:22 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Display Beolab 4500
    Are you using the right powerlink cable?  You need the thick, Mk II version.
  • 05-21-2011 4:19 PM In reply to
    Is the switch on the side of BeoLab 4500 in the AUDIO position?
  • 05-21-2011 7:43 PM In reply to
    Yes, the switch is on audio position
  • 05-22-2011 5:32 AM In reply to
    Do you use complete Powerlink cables with the plugs mounted from factory or have you soldered the plugs on yourself?
  • 05-23-2011 6:49 AM In reply to
    Ok i have MK 3, i will buy MK 2
