Latest post 05-25-2011 2:49 AM by Dave0280. 7 replies.
Page 1 of 1 (8 items)
  • 05-19-2011 10:31 AM
    • Dave0280
    • Top 500 Contributor
    • Joined on 03-05-2008
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Beogram 4500 compatible with a Beomaster 3500?
    Hi all - I've acquired over time a Beocord 3500, a Beomaster 3500 and recently a Beogram 4500 CD. Will the 4500 seemlessly go into the setup. The tops are pretty tired on all so i'm thinking a restoration project and possibly a chrome finish for all or paint all the tops gloss white like i've seen on a thread on here and it looked fantastic.
    Dave
    Dave - Birmingham, UK
  • 05-19-2011 11:05 AM In reply to
    Re: Beogram 4500 compatible with a Beomaster 3500?
    Hello Dave,
    according to the service manual there's no difference between CD3500 and CD4500 except the 3 mechanical parts chassis, cover & top plate.
    So this should run smoothly
       Gunther
  • 05-19-2011 11:29 AM In reply to
    I confirm that the only difference is the cosmetic finish. They are 100% interchangeable.
    Regards Graham
  • 05-19-2011 11:54 AM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Fantastic - thanks gents, look forward to a little restoration project....
  • 05-19-2011 12:00 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Glad you liked the white 4500 project. I say do it! Yes -  thumbs up
    Your thread has reminded me, I need to finish some things on my 4500 pieces.
    Evan
  • 05-19-2011 3:15 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Dave0280:
    I'm pretty certain that the 3500 panels are polished underneath the grey paint. I seem to recall a Beoworld member stripping the paint off with nitromorse paint stripper to obtain a match for the 4500 components. Obviously no abrasive papers or substances were used to do this as that would completely ruin the polished surface.
    Chris.
  • 05-19-2011 6:13 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Great alternative Chris.
    There is a picture of a 3500 Master that was converted this way in the Flash your B&O thread.
    Evan
  • 05-25-2011 2:49 AM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Thats interesting as on closer inspection the 4500 panel is pretty good (8/10) so i wouldn't mind having a go at trying to get the others back to the polished finish.... Nitromors is a pain to source where i am - would cellulose stripper do the job?
    A user called A2bur put a thread on this on the old forum - anyone point me in the right direction as i'm going to have a go.....
    Thanks guys
