enter the v8000 menu
select "SETUP" and press [PLAY]
you are now in the "SETUP" menu
now press [0] [0] [PLAY]
you are now in the "SERVICE" menu
select "COMPATIBILITY SETUP" and press [PLAY]
you are now in the "COMPATIBILITY SETUP" menu
change the "REMOTE CONTROL" setting from "BEO4" into "BL1000"
You can also change the menu colour into "GREY" or "BLACK" depending on which colour your Beovision menu colour is.
press [PLAY] to confirm the settings or [STOP] if don't want to change the settings.
Put the v8000 in stand-by and disconnect the V8000 from the mains and reconnect the v8000 again.
