Hi
Does anyone have half a masterlink cable?
Mine was cut to get it through a wall (well, several actually - a 25m cable), and joined with masterlink junction box (like this one from sounds heavenly)
The problem is that it was cut too near the end - about 3 inches from the plug and now I can't get it into the back of my beolab.
All I need is one plug with about 8-10 inches of cable attached.
Also, if you have an insertion tool for the above mentioned box, that would make my like a little easier!
Beocentre 6-26, DVD1, beolab 3500, beocom4, beotalk 1100.
