Hi Forum,
I have a setup around a Beomaster 3000 receiver and want to connect 2 speakers with around 20w each to output set B and 2 speakers with around 40w each to output set A. I feel that this might drain to much power from the amp (though I hardly every pump up the volume to party level). So I thought about leading the output from the Beomaster to a power stage before routing to the speakers.
Does anyone have recommendations on this? Will any power stage do? Should I place the power stage close to the Beomaster and go with the speaker wires from there (which I would prefer) ?
Or are my worries without reason?
Yours,
Ray
