Latest post 05-19-2011 11:53 AM by November35. 4 replies.
Page 1 of 1 (5 items)
  • 05-18-2011 4:28 AM
    DVB-S/T Module for BV7
    Dear all,
    I have the DVB-S module as in the picture and it should fit into BV7-49 MKIII+MKIV. On the Mounting handbook the code 1438300 and 1438400 is statet. Can anyone tell me if this module also fits for BV7-32 MK2/3/4?
    It should also be DVB-T but I miss a socket for it. Can you confirm?
    Thanks a lot,
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 05-18-2011 3:32 PM In reply to
    Re: DVB-S/T Module for BV7
    Hi, it wont fit a MK2 for certain and a combined DVB-T&S wasnt avaiable if I can remember for the BV7-32, it also looks like your missing a cable for the T connection.
    Regards Douglas
  • 05-19-2011 3:17 AM In reply to
    Hi Douglas,
    not sure I fully understand.
    Do you think it works as DVB-S for a BV7-32 MK3 upwards?
    Heribert
  • 05-19-2011 6:44 AM In reply to
    Hi Heribert,
    DVB modules for BV7-32 MK1,2&3 are diffrent from modules for BV7-40, DVB Modules for BV7-40 MK1&2 are diffrent from Modules for BV7-40 MK3,4&5.
    You can allways check what modules were/are avaiable still for older products on the Bang&Olufsen Product Archive site!(Google It) with their respective model numbers.
    For e.g a BV7-40 MK2 had its own DVB-S or DVB-T module but can now be upgraded to take the newest DVB-HD module.
    Regards Douglas
    p.s I hope this is a bit clearer
  • 05-19-2011 11:53 AM In reply to
    4384 Module work ONLY whit 7-40 MKIII (Type 9370-9384 and 9388), 7-40 MKIV (Type 9439-9455) and 7-40 TV (W/o DVD-BD Type 9456-9471).
