Latest post 05-14-2011 4:13 PM by Odd88. 4 replies.
Page 1 of 1 (5 items)
  • 05-12-2011 2:21 PM
    • Odd88
    • Top 500 Contributor
    • Joined on 07-25-2010
    • Norway
    • Posts 86
    • Gold Member
    Beocenter 2
    How should I connect beocenter 2 up as a DVD player with my beovision 8-40, when I use my beosound 9000 cd player. Should beocenter 2 be connected to masterlink or not.
    Blame google translate for my bad EnglishStick out tongue
    My Bang & Olufsen.
    • Beovision 8-40
    • Beosound 9000
    • Beolab: 5/3/2/8000
    • Beo 5 / Beo 4 / Beotime
    • Form 2 / A8 Earphones
  • 05-13-2011 3:52 PM In reply to
    Re: Beocenter 2
    I believe there is a software update for the BS9000 that addresses this, how old is your BS9000?
    I have the 8-32, BC2 through masterlink and BS9000 is connected through AUX to the BC2.
  • 05-13-2011 5:14 PM In reply to
    • kai
    • Joined on 11-16-2008
    • Posts 81
    Re: Beocenter 2
    If you want to just use it as a DVD player simply connect via the scart lead
  • 05-14-2011 3:13 PM In reply to
    Re: Beocenter 2
    Isn´t it that only one audio master is allowed in one masterlink  setup? At least that is what my dealer told me.
    I am using my BeoCenter 2 as a DVD player only and have connected it via scart only. The BeoSound 9000 is the audiomaster.
    Beo Time, A8, EarSet3i, EarSet2, BC2, BC6, BL3, BL11, Apple TV1, BEO Ballpen, BL2000, BL3500
    Christmas 2010 Prize Draw 1st winner. BeoSound 9000 Mk3
    Thank you
  • 05-14-2011 4:13 PM In reply to
    • Odd88
    • Norway
    • Posts 86
    • Gold Member
    Re: Beocenter 2
    I finally Got my beoworld price today:) and I connected it whit scart only and it works as I had hoped, just wanted to get the cabling don before it arrived. Sorry for my bad English
    My Bang & Olufsen.
    • Beovision 8-40
    • Beosound 9000
