Latest post 05-28-2011 10:54 AM by beobor1. 8 replies.
Page 1 of 1 (9 items)
  • 05-12-2011 12:50 PM
    Config tool : how to set A.Settings Beolab 3500 (Link room)
    Hello,
    I'm new on Beoworld, this is my first post. I've read several posts.
    My setup is a BV10 with 2 beolab 6000's (zone Living) and a beolab 3500 (Zone Kitchen) in the same room. The config tool (4.11) displays A.Settings in Blue (Zone Kitchen). Beo5 displays A.Settings in Grey and I'm not able to click it. I want to control sound (loudness, bass, treble, balance) on the beolab 3500. Can someone please help me.
  • 05-14-2011 4:55 PM In reply to
    Re: Config tool : how to set A.Settings Beolab 3500 (Link room)
    Hi Beobor1 and welcome. Once you select an audio source on the Beo5 for the desired product/room you wish to control, press the scene key on the remote and A.Setup will be accessible and you will be able to control the function as you wish. It remains blue if you select the scene button first. I hope this helps!
  • 05-17-2011 1:03 PM In reply to
    Thanks w5bno123,
    If I select an audio source on the Beo5 and then press the scene key, A.Setup is grey. Option Hide/Show on Beo5 makes no difference.
  • 05-19-2011 11:08 AM In reply to
    Are you referring to the remote when you see it in the configuration tool or actually in your hand?
  • 05-20-2011 10:53 AM In reply to
    I'm referring to Beo5 in my hand.
  • 05-25-2011 5:20 AM In reply to
    Hi sorry for the late reply. Who programmed this for you? I would take it back to them for it to be reflashed! If you are near to west London then I can help you too!
  • 05-25-2011 1:39 PM In reply to
    Thanks, but London is not near to me. I have CT 4.11 can you give a hint what settings I have to adjust.
  • 05-25-2011 4:30 PM In reply to
    If you can provide me with the serial number of the Beo5 then I can look up the configuration on the server for you (providing it's been stored on there!)
  • 05-28-2011 10:54 AM In reply to
    My B&O dealer will reset it. Thanks for your response.
