Latest post 05-11-2011 3:05 PM by Søren Mexico. 2 replies.
Page 1 of 1 (3 items)
  • 05-11-2011 12:22 PM
    FM aerial
    What you recommend for the FM aerial for Beomaster 5500?
  • 05-11-2011 2:57 PM In reply to
    Re: FM aerial
    The best will clearly be a dedicated external aerial. It does however depend very much on your situation and signal strength. If in a good signal area, almost anything will do!
  • 05-11-2011 3:05 PM In reply to
    Re: FM aerial
    I use a 50 Cm cable strip connected to the FM with an alligator clamp, works for me, but we have very good reception in my area, next step will be the rabbit ear and if that does not work, next step is an outdoor dedicated FM antenna.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
