Latest post 06-09-2011 9:10 AM by tournedos. 9 replies.
Page 1 of 1 (10 items)
  • 05-08-2011 11:50 AM
    beosystem 7000 and MCP 5500
    Can the master control panel 5500 control BeoSystem 7000 or I have to find a BeoLink 7000? Thanks
    Filed under:
  • 05-08-2011 12:33 PM In reply to
    Re: beosystem 7000 and MCP 5500
    Yes it will work fine. A Beolink 1000, Beo4 or even Beolink 5000 will work as well.
    -mika
  • 05-08-2011 12:54 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Be aware that any timer settings programmed with a MCP5500 will need to be cancelled using the same device. The same goes for the Beolinks 5000 & 7000.
    Chris.
  • 05-21-2011 7:09 AM In reply to
    But my mcp 5500 not control beomaster 7000? On it  there is "no connection"? Why?
  • 05-21-2011 11:25 AM In reply to
    Do you have any other remote to try?
    -mika
  • 05-21-2011 1:17 PM In reply to
    No, i have only MCP 5500
  • 05-21-2011 1:44 PM In reply to
    All right, try placing the MCP very near to the front panel of the Beomaster, as there could be a problem that reduces the range.
    If it still doesn't work, I suspect that your Beomaster has been connected to a Beovision earlier and was programmed to Option 0, which means that it won't respond to IR commands. The bad part is that I don't think there's any way to reprogram it with the MCP - you would need to get your hands to a Beolink 1000 or a Beo4, at least for the time of the programming.
    -mika
  • 06-02-2011 11:16 AM In reply to
    Beolink 5000 would be ok with beomaster 7000? or has it the same problem of mcp 5500? thanks
  • 06-09-2011 8:55 AM In reply to
    I tried with a BeoLink 1000 but the Beomaster 7000 is not responding.  could be a problem of Beomaster 7000?
  • 06-09-2011 9:10 AM In reply to
    It could be the option programming issue I mentioned earlier.
    With the Beomaster in standby, press "sound", "1", "store" on the Beolink 1000. With a bit of luck, all the remotes should now work...
    -mika
