1st March February 2012
05-08-2011 8:58 AM
HarryPierce
- Joined on 12-02-2010
- Posts 80
Beomaster Veneer Repair-Cannot Find the Right Grain
Hi Vintage Enthusiasts:
I am trying to find veneer with the proper grain to fully restore my recently re-capped and re-bulbed (thanks for the bulb set, Martin!) Beomaster 1900. The local stores here in Tampa do not have anything close to that finely grained rosewood or teak that was used on these beauties.
I was wondering if anyone had figured out a reliable source for such veneer, and also what stain brand/shade to combine it with to get that beautiful perfect reddish look.
Thanks much in advance for any advice!
Rudy
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Re: Beomaster Veneer Repair-Cannot Find the Right Grain
Veneer patterns vary a lot (it's nature after all), don't expect all Beomaster 1900s to look the same. B&O used three or four basic patterns and even within the individual patterns the veneer graining varies quite a bit. If you can take - or find a photo of the veneer pattern, you are looking for, we may be able to help you better.
HarryPierce
- Posts 80
Here is a picture of the veneer remnant that I have. The original may look a tad more red than it came out on the pic. Thanks!
Rudy
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Looks like teak, check here, the pics on the link is, as I see it, unthreaded veneer, if sanded and oiled (I use boiled linseed oil) it will apear darker.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Dillen
- Posts 5,008
The sides were both perfect and the front had a 3x2mm chip so I only reveneered the front and then matched it to the sides.
Søren Mexico
- Mexico city
- Posts 1,621
Checking my Teak S45 and Palisander BG 2404, I think Martin is right (as always), Palisander=Rosewood, same link as above has it over here.
Søren Mexico
- Mexico city
- Posts 1,621
Dillen: The sides were both perfect and the front had a 3x2mm chip so I only reveneered the front and then matched it to the sides.
@Martin, which glue type do you use, I had lose veneer side, and crazy glue did not work.
Dillen
- Posts 5,008
I use a good contact glue, just not in the "contact" way. Apply glue to the base and then clamp the veneer on. Cut, trim, grind, polish and oil the veneer when the glue has fully set. Make sure to get glue out to the edges or the new veneer will chip again very easily, you can remove any excess glue afterwards.
Søren Mexico
- Mexico city
- Posts 1,621
HarryPierce
- Posts 80
Hi Martin, Soren,
Thanks much for the replies! Did you use non-backed (i.e. "100% wood") veneer?
The links you posted, did you buy from them before, or are these just examples? I am asking since I already bought some veneer online, and the product that arrived at my doorstep looked somewhat different than the picture given on the website...Hence, I am trying to find someone who actually delivers consistent quality matching the information given.
Soren: I searched the Woodcraft website for "rosewood veneer" and several items came up, including some called Bubinga (which actually might be an almost fit...). Which one did you refer to/use?
Staining: Martin, did you use a wood stain for the turntable, or did this come out as it shows in the picture just after putting some oil on it?
Thanks much in advance for your patience with my rookie questions!
Rudy
Dillen
- Posts 5,008
I use 100% wood. No backing.
I have not bought from the Ebay seller so I cannot tell if he delivers exactly what is shown. It was just a listing, I came across. Wood veneer is real wood and, per nature, varies quite a lot from lot to lot and even from tree to tree. Actually, there is not a palisander tree (though some people call the brazilian rosewood sorts by that name). Palisander is typically rosewood that has been more or less toned which also means that it comes in hundreds of variations. A consistent supply of just one variation is hardly possible but a dealer with a huge selection may come close.
The Beogram had a little palisander oil, that is teak oil with a tiny, almost unnoticable, amount of red color to all three panels. Every veneer repair I make is different, but if I remember correct I treated the front strip with an additional tiny amount of Mr. Sheen (Topps) Scratch Cover (and that must have been the medium wood version), not to cover scratches but to add a hint of brown to the finish to match the somewhat aged original side panels. Probably only gave it a few seconds and then wiped away.
Veneer repairs is a whole world of its own. There are no rules and hardly any consistency.
Søren Mexico
- Mexico city
- Posts 1,621
As Martin, I came across the listing and have not bought from this seller, I posted the link because you are over here and it would be easier for you to get it. As Martin explains, woodworks is a sience and only mastered with trial and test, if you want exactly the same grain and color, you are in for a job where you will have to check several different pieces with your existing, when the grain is found comes the color matching and then the right glue to attach it, Martin recommend a good contact glue, applied only to the piece and not the veneeer, then comes the fitting with sanding and polishing, then oiling or lackering with your color mixture. If you want perfection you are in for a long run.
But remember wood is a beautiful and living material, it change color with time and light, a difference in color or grain will not be seen from people who does'nt look for it, and also if there are small differences between F.eks. sides and front, it does'nt mather, because its wood and not some fricking platic laminate.
Before you start maching new veneer grind or polish your existing, the color will change and it will help conditioning the wood when finishing and adding the last oil layer, I use for all my wood only cololess linseed oil, it gives a nice silk glans and gets hard enough to withstand normal use, and after a couple of years you can freshen it up again with a light fine sanding and oiling. I never use laquer or, god forbid, polyurethane for indoor wood
Page 1 of 1 (13 items)
