The "handles" to which you refer are actually the brackets which have been connected to the BeoCenter 2300 for wall mounting. They connect to a metal plate that you install on the wall. Even with the BeoCenter 2300 not wall mounted, I like having the brackets on it to use as handles for easier transport.
