Latest post 05-03-2011 9:28 AM by stampfki. 3 replies.
Page 1 of 1 (4 items)
  • 05-02-2011 11:44 AM
    Option Beovision 1
    How can I set the Beovision 1 that it only reacts on LINK + Source? I have a Beovision 4 and this BV1 in one large room so sometimes the BV1 switches on when remoting the Beovision 4.
    Thanks in advance!
  • 05-03-2011 5:40 AM In reply to
    Re: Option Beovision 1
    no clue?
  • 05-03-2011 5:48 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Try V.OPT 4. I dont know if the BV1 can handle option 4. Are your main BV (BS3?) and your BV1 connected in a masterlink system?
    Stefan
  • 05-03-2011 9:28 AM In reply to
    Hi Stefan,
    no it is a BS2 and the Beovisions are connected via masterlink.
    I'll try it.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
