If you disconnect the short lead from the BL amp then connect your external amp lead on to the terminal posts they will then run as standard (passi8ve) speakers with no problems
You also have a pm
salut
tony s
									    I always try to operate using/following the KISS principle --  Keep it simple stupid!
