Latest post 05-01-2011 9:39 AM by covent. 10 replies.
Page 1 of 1 (11 items)
  • 04-30-2011 2:16 PM
    • covent
    • Not Ranked
    • Joined on 03-12-2011
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    CD problem with BC9500
    I have problem with the CD on my BC9500.
    Everything workes fine on the BC9500 (Tape, Phono, Radio, Aux) beside the CD. The prblem I have is, when I switch to CD it gives me some kind of noise/hum in the speakers and the cd starts to spin and after a while the BC9500 just turns it self off.
    Anyone who knows what could be the problem?
  • 04-30-2011 3:15 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: CD problem with BC9500
    capacitor problem? c5104(?)  do asite search it is well reported
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 04-30-2011 3:51 PM In reply to
    • covent
    • Not Ranked
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    I have made a site search for this problem, but can't fine anthing
  • 04-30-2011 3:58 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    It could also be a dirty laser lens.  Have a look HERE
    Poor me, never win owt!
  • 04-30-2011 4:10 PM In reply to
    • covent
    • Not Ranked
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    thanx for your help, but not the same problem.
    as soon as I switch to CD source (press CD on the BC9500) it gives me a hum/noise in the speakers and the cd starts to spin and then the whole BC9500 turns it self off. It doesn't matter if I have a record in the cd player or not.
  • 05-01-2011 2:12 AM In reply to
    • ProGram
    • Top 500 Contributor
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    The whole CD part comes from Philips (not only the mechanics) and from Philips I know of some problems with open solder joints on that pcb. I mean the pcb at the left side near the cd-mechanic (not under it). Important are the grounding joints, even if they seem to be in good condition. Remove old solder and resolder on both sides anyway. Don't forget to look after the "usual" dry joints (connectors, regulator-ic, ...).
  • 05-01-2011 2:59 AM In reply to
    • covent
    • Not Ranked
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    could C2396 causing the problem?
    seems like one of the legs for it is broken
  • 05-01-2011 5:49 AM In reply to
    Well it definitely was not designed to have a broken leg Smile
    It might not be the only problem, but start there. The power supply of the CD section will be very unstable with that filter cap missing.
    -mika
  • 05-01-2011 6:17 AM In reply to
    • covent
    • Not Ranked
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    it was the C2396, I just fixed the leg and now the cd player is working like a charm :-)
  • 05-01-2011 8:38 AM In reply to
    • Step1
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    You really need to establish why this capacitor has lost its leg or footing. Could simply be a dry joint, but if it has broken you need to check that the capacitor ends are not bulging, as this is a sure sign of failure!
    Olly.
  • 05-01-2011 9:39 AM In reply to
    • covent
    • Not Ranked
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    it wasn't broken, it was the soldering that was poor and that made that the leg was lose and I thought it was broken.
