Latest post 04-26-2011 5:05 PM by Søren Hammer. 4 replies.
Page 1 of 1 (5 items)
  • 04-25-2011 2:00 PM
    Beosound 8 & ipod touch
    I recently purchased a Beosound 8, and it works great with my iPad. I also have an older ipod touch (1st gen, I think), but when I connect it to the Beosound, no audio is played. It appears to playing the track, and the Beosound remote lets me change track and change the volume level, but no audio is heard. I believe the ipod has the latest firmware.
    Is the 1st gen iPod touch compatable with the Beosound 8? Any other suggestions? Thanks
  • 04-25-2011 6:33 PM In reply to
    Re: Beosound 8 & ipod touch
    Welcome to the forum and congratulations with your new(-ish) B&O product Wink
    As far as I know, there shouldn't be any problems exept that the older ipods charges its battery on one of the other "pins" in the connection plug. Try to wiggle the ipod in the connection plug, or see if there is dust and dirt in the plug of your ipod (just like the old Nintendo cartrigdes!) Smile
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 04-26-2011 4:40 PM In reply to
    Thanks for your response. I tried giving the connection a clean, but still had no luck with getting it to work.
  • 04-26-2011 5:02 PM In reply to
    davew2011:
    Are you sure? 3.1 is the latest.
    You need to buy it, if you are still on 2.x, though..
  • 04-26-2011 5:05 PM In reply to
    My 3rd gen ipod Touch is at version 4.2x, try to update Smile
