Latest post 04-25-2011 2:51 PM by lausvi. 1 replies.
Page 1 of 1 (2 items)
  • 04-25-2011 12:41 PM
    Beovision LX2802 - no sound
    Hi, I have a Beovision LX2802 (model 3807) that I can't seem to get the sound to work.  I was given it many years ago, and it worked then.  Unfortunately in the meantime I have lost the remote, so I can only change channels by pressing the button under the front panel.
    Any suggestions?  If I had a remote, could I change the sound?  I think originally it had a Beolink 1000.
    The sound does work through the headphones..
    Thanks in advance!
  • 04-25-2011 2:51 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Re: Beovision LX2802 - no sound
    I don't know this model but most Beovisions can store any volume level for default, it might be set to 0. Or it might be set to external speakers only etc. You will need a remote to find that out.
    Bang & Olufsen - The art of controlling sound, picture and light
