Latest post 04-25-2011 1:26 PM by stotty1111. 1 replies.
Page 1 of 1 (2 items)
  • 04-25-2011 6:49 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BL 5000 repair - ribbon cable end
    Hi all
    Started to look at the BL 5000's, got one up and runningWhistle, now have a problem with the male ribbon cable end on the display feed, its fallen apart, however I think it can be salvaged, just need advice on the type of glue to use, or just double sided tape?
    salut
    tonyConfused
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 04-25-2011 1:26 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BL 5000 repair - ribbon cable end
    Hi all
    Sorted the ribbon cable end, used some permanent phjoto spray mount - works a treat!
    ssalut
    Tony
