Thanks folks. Martin interesting regards the soft clipping I will
look at this when I come to scope the output and compare with the amp in
the 6000!
ok tonight I have mostly done some little things here and there...
I started with the processor and display boards. Yep there were drys alright, quite a few actually... These were the obvious ones!
Also on the display board, I will order new bulbs to replace the original ones. Might try some LEDs yet not sure...
I also checked board 4 (tone volume etc.) while it was exposed nothing serious but went over some bits mainly plugs.
ok so as I need to get other bits on the bench to compile an order list but before I do this I figured there were a couple more jobs I could do now so saving time.
I decided to clean the two tone control pots. As most know these get quite dirty to the point where it becomes audible. We all hear Martin suggesting the only way to clean these is by pulling them apart. I don't think you fully appreciate the truth of this until you actually do that!
Here is a before and after shot, switch cleaner doesn't really do a great deal tbh!
Next the speaker switches also get quite tarnished internally and IMO are worth stripping and cleaning. Sometimes it is so bad that they stop working altogether!
Quite an easy job just a little fiddly to get back together! You can see that I have cleaned one half of the contacts below, this includes the fine edges as shown with the pieces stuck in the platerceine.
The trickiest job is to solder the switch back some helping hands are useful here!
ok so jobs to do now are recap (there is a heavy ripple on the 10V
line nearly 2v I might relocate the replacement capacitor away from
the rather warm rectifier, as I have done in the Beomaster 6000)
replace the pots I am able to setup properly afterwards, this means
some in the radio section will stay put!) and sort out the noisy
transistor in the right hand channel, but will wait until I recap as
I might as well do the job of removing the board once!
One more thing - I investigated the jumping display when tuning. I
noticed the auto / manual tuning switch didn't seem to be making any
difference, despite the manual light coming on. Investigating the
diagram, and checking the processor outputs on Plug 85 I noticed
there was no change on pin 5 (aft on) when I a switched between
Manual and auto.
Studying the diagram more closely made me realise what had
happened! When I pulled the front panel off pcb 4 (tone controls
etc.) I didn't worry about the four buttons (store x2 monitor filter)
as I figured I could test without for the time being, I knew they all
worked and filter at least could be accessed via remote. I hadn't
realised the controlling half of the man / auto switch was actually
part of that matrix (phase 3) for the other four switches, so of
course it was able to control the manual lamp, but the processor
never got the signal! - silly me Anyway there's a warning for
future repairers!
I think that is it until I order the bits required. Decided to go
for Panasonic electros nothing special FM FC and Vishay for the
axials. There does not seem to be a supplier that has the full range
in a particular type in the UK so finding what you want is a bit of a
hunt! If anyone knows another supplier other than the usual RS /
Farnell etc let me know! Not interested in Boutique tbh I do not want
to change the sound, just increase longevity.
SO the amp will go back together for now until I get the
replacement parts, I might take it downstairs and try my S120's out
and see how it sounds!
I have a few other little jobs to do now I recieved some belts and bits off Martin so might not update this thread with anything exciting until next week.
