Latest post 04-26-2011 7:04 AM by Silou. 4 replies.
Page 1 of 1 (5 items)
  • 04-18-2011 5:44 PM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Lab 3500
    Hi
    Beolab 3500 used via the 8 pin mcl now changed to a beosound 3000, how do I activate the masterlink socket, i presume I must go into a service menu
    Kai
  • 04-19-2011 3:17 AM In reply to
    • petermc
    • Joined on 04-16-2007
    • Shepparton, Australia
    • Posts 87
    Re: Lab 3500
    Just had a look at the instructions for my BL3500.
    It doesn't mention any procedure for swapping between MCL & Beolink.
    My guess is to power down your BS3000 & BL3500, connect the masterlink cable to both products and switch the power back on. Switch the BS3000 on first and then the BL3500. I think the 3500 will recognise that it is now on Masterlink automatically.
    From memory the clock can take a little time before it displays.
    Hope this helps
    Peter
    Filed under:
  • 04-19-2011 4:57 AM In reply to
    • AdiS
    • Joined on 07-24-2007
    • Posts 196
    Re: Lab 3500
    You have to change the setting in the service-menue. To get into the service
    menu to switch between ML & MCL press MENU then  MENU then 0 then 2
    then PLAY, then use the up arrow to switch, then store. It´s easy with BL 1000!
    http://www.beoworld.org/faq_view.asp?id=80
    regards, Adrian
  • 04-19-2011 6:24 PM In reply to
    • kai
    • Posts 81
    Re: Lab 3500
    Adis
    Thanks for the reply will give that a go at the weekend
    Regards
    Kai
  • 04-26-2011 7:04 AM In reply to
    • Silou
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    Re: Lab 3500
    and to go back to MCL ?
    Thank's
