Latest post 04-19-2011 5:37 PM by joeyboygolf. 8 replies.
Page 1 of 1 (9 items)
  • 04-18-2011 12:32 PM
    Oscilloscope and tone generator
    Does somebody on the forum use their PC as oscilloscope and tone generator, if yes which software do you use ??
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 04-18-2011 12:54 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Oscilloscope and tone generator
    I use my iPod touch as a tone generator.
    "Audio Tool" by performance audio.
    Evan
  • 04-18-2011 12:59 PM In reply to
    Evan:
    I use my iPod touch as a tone generator."Audio Tool" by performance audio.
    Thanks Evan, any experience with Oscill. software ??
  • 04-18-2011 1:36 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I think you need to spend a decent amount of money to get a half decent PC scope - I might be wrong but IMO you are better off with a decent second hand CRO! They have plumeted in price since LCD units have become cheaper and more powerful!
    You can get some scopes with built in waveform generators but you should be able to get a nice little audio waveform generator in kit form for a nice cheap price. Maybe even look for circuits on the net?
    Olly.
  • 04-18-2011 4:11 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    No scope experience Søren. At least not yet.
    Sorry.
    Evan
  • 04-18-2011 4:49 PM In reply to
    As a field service tech I use a PicoScope USB scope from http://www.picotech.com/, it's nice and compact which is very important for me. Quite cheap too.
    /Stefan
  • 04-19-2011 4:56 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    No experience here, but my friendly local electronics surplus store has many second hand units.  Would you like me to take some photos next time I'm there?  I've seen scopes on a popular auction site as well, though I've never bid on one.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 04-19-2011 5:20 PM In reply to
    The problem with second hand Old Skool oscilloscopes is that they may fail and be uneconomical to repair. You might not be able to trust the calibration, and the CRTs in well-used units can be quite dim (usually not a problem in audio work, though).
    I would suggest a PC scope, they are rather inexpensive nowadays and you usually get all the goodies (like memory) that will be missing from lower end real scopes. For some very rudimentary audio work, just might get by with a software scope that runs through the audio card, I believe there are a number of free applications for that (perhaps not for Mac users, as they all have a lot of money to spend Big Smile ).
    Having said that, I have a Tektronix 2235 myself that I bought used about 15 years ago, and it gives great service!
    EDIT: Yes, those PicoScopes are quite nice. Also, sites that sell everything Chinese have standalone mini scopes with LCD displays for less than a hundred bucks (the size of a cell phone). I don't think I'd want to use them for any serious work but they might do the job, and won't hog your desk.
    -mika
  • 04-19-2011 5:37 PM In reply to
    I use a used Farnell DTV20 that I bought on ebay for £40 and a Tenma audio generator that cost less than £10.
    I decided that this was more convenient than using the computer, as that is in pretty much permanent use on other tasks.
    Regards Graham
