I have two beolab 4500 active loudspeakers. Are they compatible with beomaster 5500 or beocenter 8000? beomaster 5500 has not power link, is it a problem? Thanks for your reply
Beolab 4500 has also a 4-pin speakerlink connection. You can use that to connect the speakers to the BM5500. The BC8000 is a cut-down model and it has only 2-pin connection for passive speakers. You can use that but the displays in the speakers will not work.
Bang & Olufsen - The art of controlling sound, picture and light
Thanks for your reply. So, i would understand, if i use the 4-pin speakerlink connection of beomaster 5500 the displays and power amplifier in the speakers will work?
gilbert: Thanks for your reply. So, i would understand, if i use the 4-pin speakerlink connection of beomaster 5500 the displays and power amplifier in the speakers will work?
Correct
Regards Graham
