the mlgw has no way to control the B&O grafik eyes,
Alex is correct. It's much better to use either RadioRa2 Dimmers or
by the RA2 grafik eye and use that in the system.
The B&O Grafik eyes will receive commands from a BEO4/5/6 but you must be
in the room they are in to control them as there is no way for the MLGW to 'tell' them
what to do. . .
The RA2 system can be told to do by the MLGW and visa versa. . .you can use RA2 remotes to control B&O and visa versa. . .
I'm ready for something new that I actually want to buy!
