1st March February 2012
Latest post 04-14-2011 8:42 AM by kallasr. 7 replies.
04-14-2011 6:24 AM
wilburwolf
- Joined on 04-14-2011
- Posts 3
Tips for transporting a Beogram 7000 turntable
I have just bought a Beogram 7000 on eBay. The sender is keen to do what ever is needed to give it the best possible chance of arriving in one piece. I am in discussions with him regarding packing and I have advised him to remove the platter by lifting it straight up, followed by tightening the transport screws whilst the turntable is flat on a table. Finally I advised him to make a small support for the tone arm, and wrap the entire unit in foam before boxing.
Is it possible to lift the platter off this model Beogram?
Are there any other things he can do to protect the unit for transportation?
Thanks,
Cleviebaby
- Joined on 07-30-2008
- Exeter, Devon
- Posts 328
Re: Tips for transporting a Beogram 7000 turntable
Hi and welcome to Beoworld.
There have been a number of threads on this site about transporting Beograms - you're right to be concerned as many of the threads outline the receipt of damaged kit!
Here's a link to one of those, where 'DIllen' offers some advice on packing a Beogram 5005 - the original version of the deck that went through many cosmetic variations until it ended up as the 7000 - but basically the same deck.
http://forum.beoworld.org/forums/p/26002/207625.aspx#207625
Of course, ideally you should pick it up from the vendor!
Cleve
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Yes, you can take the platter off.
Make sure the sender packs the beogram in one box and then this box and the platte in another box.
Just sent one like this myself, it arrived safely ;-)
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
kallasr
- Posts 1,077
And I would put a "cover" between the acryl top cover and the player:
kallasr
- Posts 1,077
AND: take off the stylus and put it in a small extra box as well!
Ralf
wilburwolf
- Posts 3
hi Cleve,
thanks for the super quick reply. I was aware the Beogram 6500 was similar setup but was unaware that the 5005 was the original version of this turntable. When I googled 'transporting beogram 7000' or '6500' I found very little info regarding this topic. I will check out the link you provided. Yes, it would be best to pick up this unit but it would require me flying 2000kms and then hiring a car and driving another 70km and back. This would cost me at least $500, and I haven't even told the misses that I bought the turntable yet!
Thanks again,
Will
wilburwolf
- Posts 3
Hi Ralf,
Thanks for the very pratical advice and really appreciate the photos! This is just the sort of info I am after. I will advise the seller to do these things. Great to know that the platter comes off. Are there any tips or tricks to removing the platter? are they sometimes hard to remove? are there any tools or techniques that can be used to help remove the platter? also is it necessary to tighten the transport screws with the turntable being flat on a table?
Cheers
Will
kallasr
- Posts 1,077
No, no tricks
No, not that I would say (they are a little heavy)
No, just lift straight upwards
Yes (one side over the edge to tighten the screw, I think there are 3)
Ralf
Page 1 of 1 (8 items)
