This can happen,but rarely,and only with the later '9500 direct drive dc spindle motor.There are fusible resistors to protect the motor supply in case of motor siezure/burnt commutator etc.If they blow,then obviously there is no motor supply.
I've never had any problems with the earlier induction type spindle motor,fitted to the first generation of '9500.
It seems you could benefit from a second opinion
