Latest post 04-20-2011 5:11 AM by falstaff. 12 replies.
Page 1 of 1 (13 items)
  • 04-11-2011 9:34 AM
    Dead Beocenter 9000
    Hi, my beloved Beocenter 9000 suddenly died on me. It is a beautiful piece of kit, which I will probably keep for it's aesthetic value alone..but naturally, I would prefer that it worked, so I wonder, does anyone out there have any idea what might cause an abrupt and total failure like this? I came to use it one day, and found the screens were dead...no lights at all. No sound, no opening doors, absolutely no function. I have fixed many TVs, PCs and other electrical stuff, usually by looking very closely for broken solder joints, burnt out components..blown caps and so on.....with this unit, I have checked for everything I can think of....fuses, circuit boards, damaged components etc. All seem ok, and yet there's no function. When you power up, the cd and tape drives spin for a second or so, and then stop. The only interesting thing I have noticed, concerns the relays. There are three that are easily seen: the first (1) is directly behind the transformer coil...the second,(2) to the right of the coil, and the third, to the right of the cd drive. When I power up I notice that relay (1) activates and remains activated, whereas, on a working Beocenter 9000, I have access to, this relay only activates for a second or so, before switching back to it's unpowered state. I notice also, that relay(2) only activates some of the time.....beyond that, the machine remains inscrutable. If anyone has any idea what I should be looking for here, I would be delighted to hear from them. My thanks in advance. Peter
    Filed under:
  • 04-11-2011 11:39 AM In reply to
    Re: Dead Beocenter 9000
    Try to resolder the power PCB, which is located behind the CD mechanism. I have had a BeoCenter 9500 in repair with the same problem, after resoldering this PCB it came back to life!
  • 04-14-2011 5:52 AM In reply to
    Hi, and thanks for the input I will pull that board out and go over it in the next day or two I'll let you know how it goes.
    Cheers Peter
    Blackrix:
  • 04-15-2011 4:38 AM In reply to
    sounds more like the cpu has problems,
    i believe Quality Dream Audio sell them and will even do the repair for you on a no fix no fee bases.
  • 04-15-2011 12:43 PM In reply to
    That was also my first guess in my BeoCenter 9500. But replacing it with a good processor did not help, resoldering did the trick. I would start with resoldering and see if that works. If not, you will have to start looking further in the Beocenter.
  • 04-16-2011 12:41 PM In reply to
    Well, I removed and resoldered the power PCB and also the mains input/fuse PCB, but sadly, there is no change. I begin to feel that it is either a solder problem....and what a lot of soldering there is in a 9000, or maybe a dud capacitor or something...I'll keep plugging away at it!
  • 04-16-2011 12:47 PM In reply to
    Hi, and thankyou for your suggestion. When you say resoldering.....you mean generally, board by board, or just the cpu? If the latter, where does it live, and am I likely to do it any harm by heating it up?
    Regards Peter
    Filed under:
  • 04-16-2011 2:55 PM In reply to
    I don't know if you have the equipment and the schematics, but I think you should try measuring. It might be the microprocessor.
  • 04-17-2011 4:03 PM In reply to
    Sadly my equipment extends to a multimeter and soldering irons, and no schematic. What you say about the cpu, rings a bell. Many many years ago, a new fangled microwave I had had for a couple of years just died. We took it to a repair man and he said it was the cpu....too expensive to replace, so he bypassed it, and the machine ran fine on basic function..obviously would not work in this case.
  • 04-17-2011 5:41 PM In reply to
    ..........the microprocessor may need re-soldering!!!!!!! I don't think so.
    This sounds like a power supply or perhaps a relay problem but you really do need to take it to someone who can take some sensible measurements.
    Where are you??
    Regards Graham
  • 04-18-2011 5:59 AM In reply to
    Yes, this is the way I'm thinking now...all the easy/obvious possibilities exhausted. I'm in Salisbury, and I gather there is a B&O dealer in Wimborne, not too far away, so I will probably run it down to him.
    Regards and thanks for the input
    Peter
  • 04-18-2011 7:35 AM In reply to
    Be prepared for them to condem it with the "can no longer get spares" excuse, maybe without even seeing it.
    Try a PM or email to member nobby on this forum. He is an enthusiast who does repairs.
    Regards Graham
  • 04-20-2011 5:11 AM In reply to
    Spoke to the closest B&O agent, and as you predicted, he told me that it would likely be uneconomical to repair, so I might try and find Nobby and have a word with him. Thanks for the suggestion.
    Peter
