Latest post 04-24-2011 1:24 AM by Spiros. 16 replies.
Page 1 of 1 (17 items)
  • 04-08-2011 2:19 PM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Link issue - Help needed
    Dear all, thanks to my dear friend Leslie, I received a blink converter 1611 to be used in my office link. However I wanted to give it a try to my home link and connect a BV3000 I have in a room to the current setup. As it does not have a pl connection, I connected only the data cable. There is no command accepted apart TV. Not with e.g. Link Sat or Sat, Link DVD or DVD etc. The master link cable is working perfectly since I use it on an overture, therefore no issues from there. Same is for the data cable. Although this is not permanent any hint/help is highly appreciated to make the test. Most probably if this works I will put a converter there as well!!
    Best regards
    Spiros
  • 04-08-2011 3:43 PM In reply to
    Re: Link issue - Help needed
    I guess you mean MX3000 when you say BV3000. If you want to use an MX3000 in a linkroom, you need an T1615 BeoLink Video. The T1611 can't be used in this setup. The T1611 is for connecting a Datalink product to an ML system in a mainroom setup, not in a link-room.
  • 04-08-2011 4:14 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Yes you are right. Was just back from 15 hours of work. It's an MX3000. Iwas afraid that the 1615 would be needed but though I should give it a try!!! Now Leslie, open you magig closet!!!!!!!!!! I'm sure there is one there!!!!
    Best regards
    Spiros
  • 04-08-2011 5:00 PM In reply to
    Spiros I have a beolink video mk2!
  • 04-08-2011 5:15 PM In reply to
    Spiros, email sent its yours! Send me the address and cover the postage and I am happy with that
  • 04-08-2011 5:20 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Nicky. Thank you so much for this!!! I already got your email and replied. I think this is the spirit of Beoworld!!! You made my day today!!!!
    Best regards
    Spiros
  • 04-08-2011 5:22 PM In reply to
    Spiros:
    Your welcome! Making your day has made my day aswell!
  • 04-08-2011 5:38 PM In reply to
    Nickyg63:
    Spiros:
    And seeing you both having made your day makes my day Wink! And to make sure you make your days tomorrow and the day after, have a nice weekend!Big Smile
  • 04-08-2011 5:41 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    That's Beoworld spirit. :)
    Best regards
    Spiros
  • 04-08-2011 5:43 PM In reply to
    Blackrix:
    @Blackrix. Now we have to close our deal to make our days happyBig Smile Give me a call whenever you have time..
    @Nickyg63 PerfectYes -  thumbs up
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 04-08-2011 5:49 PM In reply to
    Spiros:
    Spiros, now it's your chance to make my day. Give me your BS9000 and I repeat "Give"Stick out tongue
  • 04-09-2011 12:29 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Leslie:
    Spiros:
    On the way to you Leslie!! A BIG Thank you once again to Nicky. Already on the way to Greece and looking forward to installing it!!
    Best regards
    Spiros
  • 04-09-2011 2:05 PM In reply to
    Spiros:
    Leslie:
    Spiros:
    Your very welcome, payment received! Let me know when it arrives cheers Nick
  • 04-23-2011 9:01 AM In reply to
    Has it arrived yet?  I have a digit missing from the tracking number so I cannot check!
  • 04-23-2011 2:05 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Nicky, yes I received it a week ago and send you a thanking email as well. It finally worked out perfectly and enjoy it!!!!!!! Once again thank you very much for this support.
    I haven't forgotten the other. Will inform you asap!!
    Best regards
    Spiros
  • 04-23-2011 2:23 PM In reply to
    Brilliant, glad I could help!
  • 04-24-2011 1:24 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    As mentioned. This is the Beoworld Spirit!!!
    Best regards
    Spiros
