Latest post 04-09-2011 4:20 PM by w5bno123. 4 replies.
Page 1 of 1 (5 items)
  • 04-07-2011 7:37 AM
    • LarsH
    • Not Ranked
    • Joined on 06-23-2007
    • Uppsala, Sweden
    • Posts 42
    • Gold Member
    Upgrade BV7-40 MkIII to have ethernet connection possible?
    Hi!
    Thinking about upgrading my BV7-Mk III...
    Is it possible to add the ethernet connection as on the MkIV or MkV...
    BR/Lars
    ___________________________________________________________________
    BeoVision 7-40 MkIII, BeoSound 5, BeoLab 9, BeoLab 4, BeoVision 3-32, MX 7000, Beo4*3, BeoCom 2, BeoCom 5
  • 04-08-2011 4:39 AM In reply to
    Re: Upgrade BV7-40 MkIII to have ethernet connection possible?
    Hi Lars
    I am not sure, but i think not. What are you planning on using the ethernet for?
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 04-08-2011 5:03 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    On recent BV7-40/55-BDs the ethernet socket is part of the BluRay Player
    (only for "BD-Live" & BD-SW-Updates)
    Even an upgrade from DVD >> BD via retrofit kit won't help, since the BD-upgrade-kit
    has no ethernet socket.
  • 04-08-2011 8:01 AM In reply to
    Doesn't the Mark 3 already have an Ethernet socket on the back?
    Thought I'd seen one on mine, although I'm sure it doesn't so anything!
    Train Hard - Run Fast - Hit to Kill!!!
  • 04-09-2011 4:20 PM In reply to
    The MKIII with an SD DVD player does not have the Ethernet socket nor is it a feature of the BD upgrade available. If you wanted to run firmware updates this I done via disc method from the dealer/service agent.
    BR W5 BNO
