I have a BG7000 that needed the infamous drive cord attachment fix. I've done it twice before and never had any problems.
However, now something is fishy. If I try to restring the wire per the book (arm carriage to the center stop, the large pulley anticlockwise to the stop), the wire doesn't seem to fit where it should. The knot is 5-8 mm to the center of the pulley instead of in the recess it should land in.
If I finish the job like this, everything works, but the rest position of the arm is too close to the record (about 11 mm from the edge of the platter to the stylus, whereas on my 6500 the distance is about 16 mm).
Something must be wrong in the gearing, but I can't seem to find what. The large pulley turns freely as it should while restringing, and I've driven the mechanism back & forth a number of times which should sync it.
Any ideas?
