As I keep buying things, I need to make some room and get rid of things that have sat in a cupboard for ages doing nothing.
I have an early white key Beomaster 1000 that can be stripped for any spares that anyone wants or if you want the whole thing, let me know. Its the Danish versiom with Danish names on the dial. At the moment the cover is off and so is the base plate but all the bits are here. If you want to get it going again I will even give you a user manual for it. As can be seen in the pictures there are a couple of big capacitors missing. What else is wrong with it I couldnt tell you but it could well provide some useful bits. There is no stereo decoder.
No cost to any one, if you want the lot or just bits, cover the postage and there yours.
I also have a Beocord 2000 Deluxe T ( the one in the plastic case with speakers attached). This has been sitting in a cupboard for a while and it will never get used by me. From what I remember the basic functions worked, any more than that I cant say. If you wanted to use it properly then you would have to have it serviced. This again is FREE but if you want it you must cover the postage (unless you pick it up - Im in Surrey) and I think a Donation to Beoworld of say £10 is a fair thing to ask for. Postage would be about £10 - it weighs a tonne!!!
The Beocord again comes with a rather ratty but correct original users manual which is rather comprehensive.
Hope this ok to put these in the general section but as I dont want any money for myself they are not really "for sale"
Post on here if you are interested. First come, first served.
