BL 5s are connected to the BSYS3 with PL
The BM5 is connected via ML only in to the ML network (I have temporarily connected the SPDIF from the BM5 in to my lab 5s . . .I can't tell any difference)
The BS9k is connected via ML only in to the ML network
I did notice that the BM5 (when distributed) is giving the same indications (the left channel is much louder) I believe that's an ML problem. . .
HOWEVER, what is the deal with the SPDIF? I ordered SPDIF cables for my BM5 to connect directly in to the Lab5s. . but it doesn't appear the Lab5s will recognize the SPDIF coming from the BM5s. . If that's the case then what is the point of using the SPDIF connection?
I'm ready for something new that I actually want to buy!
