Latest post 04-04-2011 5:15 PM by jahur. 9 replies.
Page 1 of 1 (10 items)
  • 04-03-2011 10:15 AM
    • beopuig
    • Not Ranked
    • Joined on 03-28-2010
    • Barcelona-Catalonia
    • Posts 68
    Bocenter 2300 vs Beosound 3000
    What's the difference regarding sound quality between a Beocenter 2300 and a Beosound 3000 when used with a pair of  Beolab 4500?
    And the main difference, generally speaking,  between these two models ?
    Can both be used with a remote control Beolink 1000?
  • 04-03-2011 10:48 AM In reply to
    Re: Bocenter 2300 vs Beosound 3000
    There is NO difference in sound quality between these two models.
    The Masterlink socket in the 3000 is the only major difference between the two models. Beosound 3000's will obviosly be newer and possibly (?) more reliable but will be more expensive.
    They can both be controlled with  BL1000 or Beo4.
    Regards Graham
  • 04-03-2011 10:57 AM In reply to
    For me its the large clamper on the bs3000 (even though small clamper are out there)  I think it looks a lot more modern and when finished in a matt silver!! also the bs3000 has masterlink but the other can be linked via a module.  Hope that helps
  • 04-03-2011 1:48 PM In reply to
    • beopuig
    • Not Ranked
    • Posts 68
    Thanks for your information!
  • 04-03-2011 6:33 PM In reply to
    Also, the 3000 is compatible with N.MUSIC and N.RADIO; whereas the 2300 is not.
  • 04-04-2011 4:32 AM In reply to
    • beopuig
    • Not Ranked
    • Posts 68
    What's N-Music and N-Radio?
    Thanks again
  • 04-04-2011 5:32 AM In reply to
    Net Music (N-Music on the Beo4 soft keys) and Net Radio (N-Radio) are what B&O originally implemented in their windows based BeoPlayer software and their BeoPort hardware box.  This gave the capability to play music that had been ripped and stored in iTunes and internet radio stations.
    The capability has been extended (through programming works by some forum members) to Apple's Mac (OSX) platform as well as Apps.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 04-04-2011 8:39 AM In reply to
    • beopuig
    • Not Ranked
    • Posts 68
    Thanks elephant!
    regards
  • 04-04-2011 9:41 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    beojeff:
    The earlier versions of the Beosound 3000 (indicator: small clamper) were not capable of this, but software can be upgraded (around 100 Euro).
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 04-04-2011 5:15 PM In reply to
    • jahur
    • Top 500 Contributor
    • Joined on 02-07-2011
    • planet zonk
    • Posts 161
    my beocentre 2300 has been connected to a beolink converter box which is mainly connected to my avant via the masterlink socket. from there is a powerlink and datalink cable which in turn goes into the beocentre 2300 via a 3 way cable in the aux socket on the bc2300
    i purchased a 3 way cable from b&o and have my beogram9500 and powerlink connected to it via the aux socket on the rear of the beocentre 2300, i just unplug the beogram cable and connect up a dedicated beocable for an ipod.
    thats how i have got round linking the system.
    hope this helps and others
    (formerly nokinnikon from the old site)
