I have a beosystem 3 as part of BV4 with built in digital tuner. Recently, the tuner has begun to 'stick' on some muxes and it has to be turned off and on again to get it back.
Re tuneing has not helped the issue.
Is it possible to reset the bs 3?
Does anyone know if the latest BS3 supports mpeg 4 (HD) and a price of this module? or would it be better to get a third party freeview decoder- if so which ones are you using!
