Thanks for that!
Eventually found a Comag SL40hd - noew its here, I think the original box I saw was by Elap, probably the same unit with a different badge on it - the box is
22cm wide x 17cm deep(ie front - back) x 4.5cm high - now just need to fabricate a shelf for the stb tube shelf on my bv7-32 then I can place the small footprint TNT box on the shelf and the Comagmounted underneath as a semi permanent fixture - photos later!
Now to find the IR eye to control it9if possible with the Beo4!
salut
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
