Latest post 08-12-2011 12:28 PM by egoh. 3 replies.
Page 1 of 1 (4 items)
  • 04-02-2011 5:35 AM
    • covent
    • Not Ranked
    • Joined on 03-12-2011
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    Penta MK1 and a door that doesn't lock
    I have a pair of Penta MK1 with one kind of minor problem, the "door" (where the controls for sensitivity, bass level and power mode) can't be closed. When I press it to close it, it just clicks but it never locks the "door", it just opens at once.
    I wonder if anyone knows how to fix this, is it hard and what's the cost for the parts.
    Filed under: , , , , ,
  • 04-02-2011 6:01 AM In reply to
    Re: Penta MK1 and a door that doesn't lock
    Your B&O dealer can still supply a new door latch and fitting is relatively simple.
    Ask him to order 3034066
    Regards Graham
  • 04-03-2011 8:00 AM In reply to
    Behind the lid there is a spring to open it. After the repair don't mount this spring anymore. This will prevent the problem happening again, and without the spring the lid opens without any problem.
  • 08-12-2011 12:28 PM In reply to
    • egoh
    • Not Ranked
    • Joined on 04-12-2011
    • Austin, Texas - USA
    • Posts 77
    • Gold Member
    FYI, my US B&O Dealer has this part number updated to: 3034003 Not sure if it's the same worldwide, but wanted to let let people know in case they are trying to order this part.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
