Hi all,
Had the afternoon off so decided to solder in the U264B I recently received in the hopes of getting my beomaster 8000's radio working again.
When I put everything back together the beomaster wouldn't start up anymore. Stand by works, you can turn it on and the displays work, the processor test delivers 'TP' but the amplifiers do not come on. There are no relay clicks whatsoever.
I did the wire bridges modification and all capacitors have been replaced except for the four big ones in the amplifiers PSU.
Where should I start looking?
PS: found something odd. On the processor PCB one wire of L2 (a litte coil-thingy) is broken. The resistor parallel to this coil (R62) has some wire wound around it. is this (the broken wire) normal?
UPDATE: checked the relay board. When in TP1 I measure -22V opposed to ground on the coil of RL2, nearly as expected from the service manual, but it doesn't click. Took RL2 out and tested it with 2 9V batteries, worked fine. When I put it back in the BM nothing happens.
