Thanks for the reply Peter, much appreciated as I'm starting to struggle without my vinyl!
By Suspension, I presume this is the metal cap that slides off the cartridge (sorry, I'm new to all of this). On further analysis, should this cap slide all the way back to the metal rim of the cartridge when it's placed back on and secured with the screw as there seems to be a slight gap between the back edge of the metal cap and the back rim of the cartridge… Without the needle in place it does slide all the way back, but with the needle in it does not which is why I wonder if the plastic piece at the end of the needle is too big??
I'm just confused as the previous needle I had no problem like this, but it appeared to be a much straighter needle whereas the new needle has a bend at the end where the diamond is which again seems to be a contributing factor to the diamond not touching the vinyl… I might try to upload a couple of pictures if I can to help explain.
Thanks again for your help!
Darren
