Latest post 03-26-2011 2:38 PM by top2bottom. 2 replies.
Page 1 of 1 (3 items)
  • 03-26-2011 1:58 PM
    compatability
    Can i play a Beocord 3500 through a Beomaster 1900? The lead from the tape doesn`t fit into the tape connection socket on the Beomaster.
  • 03-26-2011 2:23 PM In reply to
    Re: compatability
    You can - however there are two problems!
    1. The tape lead has a 7 pin DIN plug - you will need to unscrew these pins so that the plug will fit the 5 pin DIN socket on the 1900.
    2. You cannot record as the 1900 uses DIN standard and the 3500 uses LINE standard. You can play tapes though.
  • 03-26-2011 2:38 PM In reply to
    Re: compatability
    Many thanks for reply. I am not too bothered about recording. Neil
