Latest post 05-03-2011 5:06 AM by guffas. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • 05-02-2011 1:09 PM In reply to
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    Re: BEO5 write timeout
    if the hardware does not work that should not be linked with the software as it is hardkey not programmed by the software-conatct B+O for service I suggest...and good luck :-)...thge service get worse and worse
    Best regards Oliver
  • 05-03-2011 1:36 AM In reply to
    It can be an issue with the software, try this trick:
    Press the centre button for 30 seconds and eait for it to switch off. Place Beo6 in the charger as battery status will be lost during this reset.
  • 05-03-2011 3:09 AM In reply to
    Hi thanks for the tip - do I do this before I apply a config file i.e. the charger being connected to the PC via USB or following the application of a config file? many thanks
  • 05-03-2011 5:06 AM In reply to
    After you have updated the Beo6 and whenever you experience the dead hardkeys.
