Latest post 04-06-2011 3:24 PM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 03-22-2011 4:47 AM
    • BegBeo
    • Not Ranked
    • Joined on 04-23-2008
    • Stockholm - Sweden
    • Posts 60
    • Gold Member
    Beosound 9000 Typ 2571 MK3 Do not play CD's - Focus error
    Got a BeoSound 9000 type 2571 EU. As the Service Menu shows CD error No.2 Focus
    Before I get to order a new service CD kit from B & O,
    I want to hear if anyone here knows if it goes to service the BS9000 without having replaced with a new CD laser and associated circuit boards?.
    Sincerely
    Jan
  • 03-28-2011 3:09 AM In reply to
    Re: Beosound 9000 Typ 2571 MK3 Do not play CD's - Focus error
    If you are lucky then the laser lens needs cleaning but in all probability the cure will be a replacement laser kit.
    Make sure that you order the right kit for your model as there are several, depending on the type number of the 9000
    Regards Graham
  • 04-05-2011 5:20 PM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    Hi Graham, I received today the CD laser kit, but before I began to work to change the CD laser I tried BeoSound 9000 and now see what happens my BS9000 works again.
    It was still unused since 23 April 2011 now works again.
    I have no idea about the error come back?. Hopefully not.
    It could have happened with control of the CD laser, that I also cleaned the laser.
    We'll see, I will come back.
    Regard Jan
  • 04-06-2011 1:52 PM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    Hi Graham, the error came back so I'm changing the laser now it works well.Trying to serve BS9000 with CD errors, Without a CD laser kit is time consuming and can not serve 100% good.
    I replace the CD laser in less that 60min. The cost was 1500, - sec, about 120, - GBP
    Regards Jan
  • 04-06-2011 3:24 PM In reply to
    I usually does require a replacement laser kit for a permanent cure.
    Regards Graham
