Latest post 03-21-2011 9:34 PM by nycbrg. 3 replies.
Page 1 of 1 (4 items)
  • 03-21-2011 4:59 PM
    Reliable NA parts source?
    Trying to rescue a BM 5500. Does anyone have suggestions for reliable N.A. parts dist. for trans./diodes/res.? I would prefer a 'one stop' if possible. I may be dreaming.  I understand these days that the internet makes the process 'global'. Not trying to exclude anyone, reliability, service, speed and selection are most important.  Thanks, Brian
    BeoMaster 8000, Beogram 8000, Beocord 8002, Beogram CD50, M100's.
    Beocenter 9500 Beovox P45's
  • 03-21-2011 6:26 PM In reply to
    Re: Reliable NA parts source?
    I've been surfing the web for the same, but considering the work with finding the correct items in the parts list, checking the same in the piece you are repairing and then ordering on the web, the best and simplest way is ordering kits from Martin, and if you want parts not included in the kits, Martin normaly provide these also.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-21-2011 8:04 PM In reply to
    Have you tried Atlantic Systems. They've done a great job repairing B&O for me in the past. I can recommend them. Perhaps they can supply the parts you need.
    http://www.atlantic-systems.com/
    781-826-8760
    Let us know how it goes.
  • 03-21-2011 9:34 PM In reply to
    Thanks, will use the advice. Brian
