Latest post 03-21-2011 8:22 AM by stotty1111. 7 replies.
Page 1 of 1 (8 items)
  • 03-20-2011 6:50 PM
    Beolab 6000 Bass Drivers x4
    Unfortunately the centres of the bass drivers have been pushed in which doesn't seem to affect the sound at all but I'd like to get them sorted. A long shot perhaps but does anybody have any of these going spare?
    Thanks, Jon
    Filed under:
  • 03-20-2011 8:03 PM In reply to
    Re: Beolab 6000 Bass Drivers x4
    Have 4 (refoamed), somewhereSmile
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 03-21-2011 3:51 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    What are you looking for? drivers or judt dust caps?
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-21-2011 4:20 AM In reply to
    Hi Tony,
    Ideally I'm looking for replacement drivers. I think replacing the dust covers will be a little beyond my technical ability!
    Regards, Jon
  • 03-21-2011 4:40 AM In reply to
    If it's just the dustcaps being pushed in you could try putting the brush on your vacuum cleaner and with increasing suction trying to get the dustcap to pop back in its original shape! Usually works very well, seems a bit overkill to replace the drivers just for this Smile
  • 03-21-2011 5:58 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Agree with Prem....  that would have been my suggestion , tied in with GENTLE lifting using a fine sewing needle - used this technique with penta dust covers very successfully
    Gice it a go - nothing to lose!!
    tony
  • 03-21-2011 8:01 AM In reply to
    I did try with a vacuum cleaner alone to no avail, and with a bit of double sided tape which just seemed to pull the fibres from the dust cover.
    So are you suggesting I make a tiny perforation in the dust cover with a sewing needle and pull out?
  • 03-21-2011 8:22 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    yes, near centre with the point to the edge then gently lever/ease up - sort of nothing to lose, lots to gain!
    t
